DSL Router
I live out in the country, and the internet her is just an ADSL connection. I was wondering if you had any opinion on routers and if there is a way to make is work w/ a pfsense box? thanks alot for all you do btw you guys got me back into pc gaming.
It works fine on pfsense, you just need an adsl modem
So, it will work fine w/ the crappy wifi modem the phone company used for the install?
yeah, turn off the wifi and put it in to bridge mode so it's just a modem.
Awesome, thank you so much.
