Drivers giving me issues, help!
I jut reinstalled windows and as soon as i download the audio drivers for my MOBO, i cant adjust my sound at all, Its stuck on mute and occasionally turns its self upto full, I uninstalled the drivers and my audio was fine, will i get lower quality audio if I dont use the drivers?
I had the same problem with my motherboard. Don't bother installing the drivers, the audio will be fine.
Demon's right.. in most cases the stock windows drivers will be fine. If you need more control or specific functions, then sometimes you need to install the drivers. What MB do you have? are you sure you got the right ones?
lower quality without drivers? no not really, if your audio sounds fine its all good, dont bother with the custom drivers :)
Shit, when will you ever learn not to be lazy and post in the right section? I thought you were talking about Muppet drivers on the roads, as I experienced.
