How do i view drive temps?
Which BSD
You might try
smartctl -d ata -A /dev/ad0 | grep -i temperature
On FreeBSD with the smartmon tools installed, as per:
Freenas 11.3
https://www.ixsystems.com/documentation/freenas/11.3-U4/reporting.html
On the Reporting page, there is a dropdown at the top where you can select the βDiskβ category. There should be temperature graphs there.
Ideally you want to keep the drives below 40C BTW.
