Hi! I am looking for something exactly like the HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer, but with DP instead. Any ideas if something like that might be comming? Any alternatives?
We have 4 PC 2 monitor DP 1.4 KVMs that support up to 4K 240Hz (DSC). For EDID, the best fix is in software rather than hardware. In Windows 11 there is a setting to remember windows locations. In Windows 10 you can download the Persistent Windows to achieve a similar EDID effect. Idk how exactly but I do know there’s a way to fix windows locations in Linux as well.
So I would recommend getting our DP 1.4 - 4 PC - 2 Monitor - 10GB KVM and use software fixes for monitor emulation:
this is sold out on our store atm, but if you’re interested DM me and I can check at our office to see if we have any put away
