I’ve just added a DP repeater between my macbook and my KVM (honestly, the fact that the L1 KVM doesn’t do EDID emulation is beyond annoying to me. It’s something I expect from a KVM.)
I plugged the repeater in a couple days ago, cloned the monitor. Everything worked - macbook thought there was always a display. Cool!
Go in to work yesterday, home again today. Monitor has turned itself off due to no signal. Plug in the macbook. The repeater is blinking green, macbook thinks my monitor is connected…monitor is getting no input though. I eventually had to remove the repeater from the setup and the macbook is connected to the KVM directly again.
Further investigation, and confirming a few things:
The monitor works as expected without the repeater.
The macbook works as expected without the repeater.
I held the button down to reset the repeater - the macbook now sees a display “V_DM10072011A” and will let me output 720P, 1080P, 1600x900 and 4k to it.
The monitor does not receive any output from the repeater even when I remove the KVM from the chain.
The LED will ONLY blink green. I cannot get either color to indicate video.
I have reset the power multiple times. I have held the button down to reset EDID multiple times.
For some reason the repeater is having trouble. Is your Mac stuff new enough to open a ticket with apple? This happened on big sur but was fixed in the next point release.
The KVm doesn’t have edid emulation because it breaks gsync/freesync. That’s also why windows 11 remembers monitor positions automatically now too. Apple will probably do the same before too long so that people have a more reasonable dock/undock experience.
The mac is from work (so while support should exist, I doubt they’ll know what to do with a repeater.) It was updated a few days prior to first using the repeater. It works fine without the repeater. Why would the problem be with the mac? Currently I’m running mac - KVM - monitor just fine. Mac - repeater - kvm - monitor was the issue.
Actually - I left it unplugged for a while. It’s now actually outputting video to my monitor again, but still I can only do the 4 resolutions I listed above. It doesn’t actually output the resolutions of my monitor (an ultrawide).
Does this need to be RMAed? The unit is days old.
I’ve tried it with my WIndows PC as well. There, it’ll go up to 1440p once I reset the EDID (hold down until cyan shows) but won’t output the correct 21:9 resolution. I did this bypassing my kVM entirely, so it is PC (rtx2080) - repeater - monitor.
Without the repeater, everything works for my PC as well.
Turn your monitor on. Wait 5 seconds. Press and hold the button on the repeater for 4 seconds.
Turn the Mac on. Boot the Mac and you should see the resolutions your Mac supports. If not press and hold the button for 4 seconds again.
This teaches the repeater your monitors edid.
Once the Mac is showing resolutions then you can hook it up the KVm. Don’t touch the button on the repeater again once it’s learned the resolutions.
There was an update for Macos a week or so ago that breaks some displays, but I’ve almost got a firmware fix. It’s on the apple side though. It’s an apple problem that happened once with big sur, but they fixed it in the next point release. This might not be that problem though.
