I currently have Level1Tech’s DP 1.4 KVM 4-Port for a single monitor.
My current use case involves the following setup:
- MacBook Pro 13" (Intel 2020) → Thunderbolt Dock → KVM
- Windows 10 PC with GTX 3080 → KVM
- KVM → AW3821DW Monitor
and I have recently encountered an issue with this setup. The thunderbolt in question are CalDigit’s TS3+ and OWC’s Thunderbolt 4 Dock. I have encountered issues with the both of them when connected via thunderbolt pass-thru ports.
Whenever I switch over to my Windows 10 PC for an extended period of time, my MacBook Pro will lose its internet. I believe this may be because my MacBook Pro enters sleep. I also believe that this happens because there’s a possibility of the absence of an EDID emulator which may be important to run the MacBook Pro in clamshell mode.
My questions are as follows:
- Does anyone work using a similar setup?
- If I am considering getting the DP repeater, will this solve my problem?
