I was hoping to downsize my PC case from a Phantom410 to maybe a Bitfenix Prodigy Case. I want a smaller case because I like the portable size and weight of it and i want to carry around it and bring it friend's house to have lan parties.
But i dont know what motherboard to use as i have a AMD FX8350. Any ideas that could help me? Maybe a list of parts that might be compatible with the Bitfenix Prodigy Case?
There are no AM3+ ITX motherboards (at the moment) and the Prodigy is biger than a micro ATX case and a lot heavier to ( 7 kg just for the case! ) There are allso not any good M-ATX mobos ether for a FX8350.
You will have to go intel if you realy what the smaller form factor anless you go for a APU that's on a FM2 mobo (these have good ITX and M-ATX mobo's but are a lot less powerfull)
If you want to stick with your current hardware and just cut the footprint I would suggest going for an M-ATX mini tower like the Corsair 350D or Fractal Define Mini.
Can I talk you out of an ITX case if you want to keep your FX-8350? How about the Cooler Master HAF XB, it's a compact cube case that fits full size ATX motherboards. I own one myself and it fits a 240mm rad or a 280mm Rad in the front of the case if you want to do water cooling or an AIO cooler.
I second Batojiri, the Cooler Master HAF XB is very easy to carry because it has handles, it is like carrying a moderately sized box and even if your harware might be in the heavy side the case factor really makes for it.
