Downloads directory on other drive?
SSD’s aren’t made for frequent writes, so I was wondering if it is possible to have the contents of my Downloads folder on a separate HDD. Is that possible, or am I just going to make a mess that way? If it’s possible, do I use mount --bind ... to accomplish that?
what OS?
Maybe 5 year ago. SSDs are fine for writes.
But yes, you can mount your downloads folder to another drive if you want, it just needs the correct line in /etc/fstab
You could bind mount, or you could symlink. Symlink would be the proper method to do it.
mv $HOME/Downloads /path/to/other/disk/Downloads
ln -sv /path/to/other/disk/Downloads $HOME/Downloads
And no, you won’t be making a mess. I have a bunch of my home folders on a lot of different drives.
Thanks for the replies :smiley:
Edit: Oh sorry, missed the first reply ! Ubuntu 18.04.
