Down to two choices
So ive been working at this for a couple months now, prices got out of hand for a while, so im back down to a limit of 1,300/400 US Dollars and ive assembled two builds. Both with the same things, except the cpu's. One build is the i5- 4670k and the other with an AMD FX 8350. I also need help with the AMD motherboard i chose. I think it is overkill i dont plan on doing any crazy overclocking. I was looking for something around maybe 150$
What i plan to do.
1. Gaming (battlefield, bioshock, really any game)
2. Possibly be able to stream games (like league of legends)
3. If needed to, some photoshop, or small video editing here and there (Sony Vegas)
4. Be the best 'bang for your buck' performance
5. Be able to overclock (nothing crazy)
i5- 4670k build: http://pcpartpicker.com/user/OedipusTheK/saved/2ZGU
Amd FX- 8350 build: http://pcpartpicker.com/user/OedipusTheK/saved/2ZH0
So those are my 2 builds. I think some things are different, like the AMD motherboard is definitely overkill (any suggestions around 150$ for a mobo?)
Also is the power supply going to be enough for future upgrades? Is the case overkill, i know that the cooler master cases, i think, are cheaper and really quiet, any suggestions on that? What kind of heatsink will i need? And will this have enough cooling?
Thanks to anyone who can help! I really appreciate it hopefully i can find some good deals on cyber monday!
I your streaming and video editing, you'll really benifit from the fx-8350's 4 extra cores, so I'd recommend to go AMD. You also probably want to get 16gb of RAM if you want to video edit, and make sure you have Windows 7 proffessional or Windows 8 pro so that you can take full advantage of that RAM.
Assuming your $1300-1400 budget, here's my suggestion: http://pcpartpicker.com/p/2bZAg
Is there any particular reason you want a Full Tower case? You could fit everything mentioned into a mid tower with a good bit of room to spare. I recommend the Fractal Design R4, as does pretty much everybody around here, and it's a really good price right now (Solid build quality, lots of routing options, quiet case, sleek look).
As to the question of which processor to build off... if it's between the Haswell i5 and an AMD 8-core for video editing, I'd give a slight edge to the AMD. If you were willing to jump up to the i7, it would blow the AMD out of the water. It's a pretty big leap in price, but it's hard to even tax all the cores on an i7 and they're a lot better at overclocking. Hyperthreading is beastly for video editing.
As far as the PSU, it depends on what you mean by upgrade? If you mean you want to be able to crossfire two high-end cards, then you'll likely want a 800-850w PSU. If you'll be using one high-end GPU, then 650w is plenty of power. (Seeing the price difference, however, the Corsair Professional 750w is a pretty good value).
Now as to Windows Professional giving you full advantage of your RAM, I'm not sure what he means? There's a difference between the 32 and 64 bit versions for accessing over 4GB of RAM, but I've never heard of any other discrepancy? I'd like to hear him elaborate on that, because you overclock the RAM in the UEFI of the mobo, so I'm not sure what he was referring to.
Nothing wrong with the mobo you picked out... that's just a really good deal on an Asus mobo... and I'll always point people towards products I've used... I've always had good luck with Asus mobo's and had a really bad experience with two Gigabyte mobos (one DOA, the replacement fried a CPU)... MSI makes quality products, but have had some mobo compatibility issues that I've seen around (not from personal experience). Also, this mobo's got pretty much all of the functionality as the one you chose for $50 cheaper.
Added a SSD for a boot/large program drive
Changed the CPU cooler to a Phanteks... it's extremely quiet and one of the higher-end air coolers on the market when it comes to temperatures... perfect for intensive overclocking...
For what you need, this build is admittedly overkill. But for $1400 you can build a legitimate beast of a PC, and this is that for sure :)
