i assume you would be overclocking your system with that H60 cooler, but with that motherboard you cannot do that. Also, if i were you, i would concider an AMD option for the CPU, since the FX 8320 has come down in price so much. It would give you simular performance as the i5, but costs 100$ less, and you could use some of that money in getting a great OC motherboard like the gigabyte one i am recommending to you. Also, games are starting to utilize more than 4 cores, so the FX 8320, would outperform the i5 easily.
A GTX 780 will be a great choise, since AMD R9 290, don't have aftermarket coolers yet, and have gone way up in the price and are out of stock. BUT if you can wait for the R9 290 to get the aftermarket coolers and come down in price a bit, i would recommend it over the 780, since they are very simular in performace, and with MANTLE, the r9 290, would get a big boost in performance, and be faster than the 780, while costing a lot less.
But here is what i would recommend, if you are getting the system now, and can't wait http://pcpartpicker.com/p/2s7L9
Thank you for taking a look at my build. I definitely need a new motherboard then, but I will not change the case. The case is micro ATX, so the motherboard you suggested is too large. Also, everywhere i read about the i5 4670k vs the fx 8320 the i5 seems to be better (at least in games) even though the price/performance ratio isn't its winning point. I will be sticking with the GTX 780, as I am a bit impatient, and G-Sync sounds good as well. :P
The i5-4670k is a good CPU for gaming, but when it comes to price/performance, the fx 8320 wins by far, but the i5 will be a good choise too :) also i would recommend to still spend a bit more to the mobo, if you are gona OC the CPU. I would be looking more like an asus Z87 gryphon, for a better and higer quality power delivery :)
yea I'm not so sure there's room to liquid cool in a MicroATX case?... 780's are pretty big too... it'll be tight... if you're sure you have room then it's a nice build
