UPDATED
I'm putting together a build for using the Dolphin emulator (www.dolphin-emu.org) that I'd like to use for everyday work activities (HD movies, MS Office on Windows 7 64-bit) as well as doing some LTC mining. Here are the parts I've selected to go along with the HD 5830 I already own. I'll be overclocking it and may add an extra video card if I continue mining.
DVD Burner ($19.99) http://www.newegg.com/Product/Produc...82E16827135204
Motherboard ($99.99) - ASRock Fatal1ty Z87 Killer LGA 1150 Intel Z87 http://www.newegg.com/Product/Produc...3157460&cm_sp=
CPU ($224.99) - Intel Core i5-4670K Haswell 3.4GHz LGA 1150 http://www.newegg.com/Product/Produc...82E16819116899
16 GB RAM ($114.99) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231615
SSD ($99.99) - Samsung 840 EVO 120GB SSD http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8466636&CatId=5300
Fan ($29.99) - Cooler Master http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4950641&CatId=99
Power Supply ($49.99) - CORSAIR TX Series CMPSU-650TX 650W ATX12V / EPS12V http://www.newegg.com/Product/Produc...82E16817139005
Case (49.99) - Fractal Design Arc Midi R2 http://www.newegg.com/Product/Product.aspx?Item=N82E16811352031
Windows 7 64-bit Home Premium ($64.99) http://www.tigerdirect.com/applications/searchtools/item-details.asp?sdtid=6479414&EdpNo=8130466&csid=_22&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&utm_source=Linkshare&utm_medium=Affiliate&utm_campaign=lw9MynSeamY&AffiliateID=lw9MynSeamY-dqrXp9YDd.z3Goh4gWVsTQ
Looking at about $755 right now after rebates. Any suggestions or problems with the combos?
