Dolphin Emulator Problems
Okay, so I've been having some problems with Dolphin EMU. I bought a GC controller and a Mayflash adapter and was really excited to get some nostalgia on. But, after I load a game, I get some issues.
The game loads up fine, and I can get to the main menu and such. But I noticed that even in the main menu sometimes the game will just randomly slow down, the audio gets very choppy, and makes it hard to navigate. As  you could imagine in-game it does this as well, I've noticed it particularly does this when I do a new action (Not sure how to explain it so I'll give an example) like when I pick up an item block in Mario Kart Double Dash. While the block is circulating to find my item, the game is really choppy, the audio gets choppy, etc.
I've tried to find a solution to my problem elsewhere, but it's really hard to get any answers because all the people that post their specs obviously can't run the emulator since their rig is terrible. And I'm pretty sure my rig should be able to handle the emulator, as I always get an FPS of 30-60. But I saw that even with an FPS of 60 it would do this slowdown, and while it is doing the slowdown, I still have 40-60 FPS which is very confusing to me.
I'll post my specs, and my Dolphin Configuration Settings if needed.
XFX Radeon HD 7850 2GB
AMD FX 6-Core 3.5 GHz
8GB of RAM
Pretty sure this is all that's needed, but if you need more information, I'll be happy to give it. Oh and I am only trying to play GC games, not Wii games.
make sure you have it set to render useing open gl instead of directx, that should help quite a bit
Oh and I should mention I'm running Windows 7 x64. I knew I was forgetting something.
Alright, set to OpenGL, trying it now, thanks for the heads up.
It works!!! Thank you so much, makes me feel a bit dumb that the answer was something as simple as that. It is running as if I were playing it on a regular Gamecube now, thanks for the help.
yeah I learned a while ago with emulation that the render makes a world of difference and directx is horribly inefficient, because you have an amd card you'll want to use open cl if it's available, or open gl still runs a hell of a lot better than directx
Yeah I see that now, and the reason I was running DirectX instead was because I read on the Dolphin Wiki that it told me to use it over OpenGL for some reason.
