So I plan on doing a pfsense box and would like a second look on what I have put together. I know the minimum requirements are 256 MB for RAM, Pentium II for CPU and 1 GB for hard drive space. I do not want to just go with the minimum requirements and I would like to have some headroom.
Is this build too much for a pfsense box? If so please give some feedback.
I agree with Qain on this, this build is quite expensive for its intended purpose.
I would personally (if you want to build one) looking at the AM1 platform (so cheap dual or quad) and use a PCI-e dual port card (loads can be acquired via eBay cheaply). I know the Intel build has wireless on the board, but pfSense doesn't exactly like wireless cards and you will have far better performance from a separate Access Point.
I quite like that machine linked on Alibaba. If you want a larger unit, a particular favourite of many pfsense users (and myself) is using a WatchGuard Firebox x-core-e series.
Not sure why most guides recommend CF and msata cards. The only reason I could think of would be if you used Squid for catching. Then that would be a lot of writing
I really appreciate all the feedback from everyone. I'll be looking into that mini pc. As far as storage goes, would it be best to just get a laptop size HDD or an SSD? I think I might want to go with a small HDD. I might look into using Squid.
You said something about the power supply. Just a regular 12V would work?
The other option is one of these. It runs about $150, but you would also need to get a case, wifi, and other fun stuff. Great for a project, not so much for turnkey type solution.
