Does USB to Ethernet Dongles Work With PfSense? (Answered)
So i watched the video from Logan about turning a old computer into an epic router and i have an old computer that is just sitting in my closet (Laptop).
And i was wondering if it is too bad hardware for PfSense?
Here are the specs:
Intel Pentium 1300MHz
256mb of RAM
ATI Mobility Radeon 7500
40GB Hard Drive can't find speed
Intel PRO/100 VE Network  Connection
1394 Net Adapter
End Of List.
The laptop is called Lenovo Thinkpad R40
http://www.pfsense.org/index.php@option=com_content&task=view&id=45&Itemid=48.html
Minimum Specs according to them are on their website.
The hardware isn't too bad. However I would personally not use a Laptop as a router. A. Due to the lack of LAN ports and any laptop expansion possibly not being quick enough. B. If it has a WLAN adapter in it, (based on the way you describe it as bad) it may bottleneck your internet connection if it is of only WiFi Standard a/b/g
Thanks and yes it does have a WiFi adapter but i have had really many problems trying to use it.
But wait i just realised i have a usb to gigabit ethernet cable is it maybe possible to use that??
Ummmm, no such thing as a USB to Gigabit (unless it's USB 3.0) USB 2.0 is not fast enough to support Gigabit LAN. It can support 100T speeds.
I do not know the support for USB adapters under PfSense. If it doesn't require third party software to use, then it might work.
It's the apple usb to (according to Apple) gigabit port.
bump
If you can find the exact product in either of the following lists. All should be fine.
http://www.freebsd.org/releases/6.1R/hardware-i386.html#ETHERNET
http://forum.pfsense.org/index.php?topic=25.0
If you don't find it in the first link, it is unlikely you will find it the second.
I'll just quickly jump in and say that pfSense does support usb-ethernet adapters out of the box, see I also recently installed pfSense on my old laptop (Aspire 5740).
I assigned the WAN interface to usb using a simple adapter, and LAN to the laptops ethernet port during the install with no problems at all. I Also tested that the laptop works perfectly as a wifi access point, but I currently have it disabled.
The topic was marked "answered", but i'll gladly help if I can if anyone else is having similar issues.
