so here are the commponents: http://www.coolermaster.com/product.php?product_id=6656 http://www.zotac.com/mx/products/graphics-cards/geforce-600-series/gt-610/product/gt-610/detail/geforceR-gt-610-synergy-edition-2gb.html http://www.corsair.com/us/memory-by-product-family/vengeance/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1600c9g.html http://www.zalman.com/global/product/Product_Read.php?Idx=640 http://www.asrock.com/mb/AMD/970%20Pro3/ http://www.amd.com/uk/products/desktop/processors/amdfx/Pages/amdfx-pib.aspx I chosed fx-4170 and i have optical and hard drive all ready. so just tell me does it work? thx
What it the focus of the rig?
normal use and in the future (when i have more money) i buy sapphire hd7870 2gt craphics card I am playing whit it
FX4170... don't know what to say about that CPU. Go with a Vishera (FX 43xx) because Bulldozer (FX 41xx) was a flop.
the vishera or philedriver FX4300 is a better cpu yes. but the FX4170 isn´t bad either.
wenn it comes to gaming performance it doesnt make a big diffrence, the biggest problems with the buldozer cpu´s where the power consumpsion, but if that doesnt matter to you, then eaven the bulldozer isnt a bad cpu to choose.
especialy for normal tasks it isnt a bad thing :)
thx for answer :) but I like to know does this work?
thx for edvice :) but does it work?
Yes, it'll work but i'd rather go for the Extreme3 instead of the Pro3. The Pro gets alot of negative reviews, and for about 5 dollar more you can get a better motherboard that's absolutely loaded.
I´ll do that. thx
