Does this monitor exist?
Looking for a 27-32" 2560x1440 165hz IPS curved g-sync monitor…does this exist or are they all TN panels or freesync?
Looking to replace a dell 27" wqhd because the colors do not seem great
G-sync is very likely to work with the Freesync monitor since ultimately only a few minor differences separate the two.
I’d not go for the cheapest bottom-of-the-barrel stuff, but at higher price points it is all but guaranteed that Freesync support equals G-Sync support - it’s just that G-Sync support costs $$$$$ to validate while Freesync support validation can be done cheaply and in-house.
Check reviews for monitors that looks interesting!
Man that’s a tough one to find. You might have to settle for the inferior FreeSync if you want to go that route. I have found some G-Sync curved 144hz (165hz overclocked) but they are “no longer available”. Probably sold out because of how awesome they are.
This is what I’d go with. Curved is not really a game changer. The difference between 165hz and 144hz is basically imperceivable.
https://pcpartpicker.com/products/monitor/#r=256001440&sort=price&F=683260000,1651000000&P=2&D=144000,280000
I started at 144Hz.
