So I am wanting to switch my graphics card to the R9 295x2 and I was wondering if the Corsiar Rm 850 had the 12 volt rails needed to power it.
Cheers
-Kenshinfo
Cheers
-Kenshinfo
70.8 amps on 12V rail so yes you will be fine
http://www.corsair.com/en-us/rm-series-rm850-80-plus-gold-certified-power-supply
Thank you
Agreed I'm running the xfx 295x2 with an old xfx 850 with slightly less amps and its fine. Just make sure you use separate 8 pin connectors (No splitters or molex adaptors).
-Brian Timothy
