I made a post a few months ago about this. No one replied. But I still wanted to know what ideas people here have. Is the value of the device the bundled software/firmware? or is there something, some feature that I'm not seeing that makes the device itself awesome? Would it lose that value from flashing it with a more simple third party firmware? I'm gonna buy the regular unifi sometime this month, and I'm gonna experiment and mess around with it before I put in some long-term set up.
Hey! I have a view things from ubnt, but I have not yet tried do flash them.. as they run smooth with what they came with.
There seem to be some stuff (specially driver) thats only in the AirOS firmware: https://en.wikipedia.org/wiki/Ubiquiti_Networks#Software
If you're only running one of them then if you want to use a different firmware then go for it. But if you have a bunch the unifi software is pretty good for managing them.
Thats true.. I can only speak for the cameras, its realy a great piece of tool, specially for the prize.
What kind of prize? I have never heard that term used before.
For shits and giggles sure, but Ubiquiti's preinstalled firmware is really just fine.
Please forgive the native german-speaker... I meant price. Like in $/€ bucks, cash ^^
At my last dorm we had 2 Unifi APs deployed that came with dd-wrt directly from the vendor. They are rock solid with that and have collected somewhere around 300-500 days constant uptime.
There is a fitting topic in the community forums from Ubiquiti: https://community.ubnt.com/t5/UniFi-Wireless/Why-should-I-keep-original-firmware-instead-of-DD-WRT/m-p/1315932/highlight/true#M114619
From what I've heard: The normal firmware on the devices is good enough.
