Does my pfsense router need multigig ports?
Hey Level One,
So I’m in need of some network upgrades. I’m currently using a Tp-link deco 5 as my router and I want to upgrade to a pfsense router as well as upgrading my main switch to support multigig connections. I was thinking of using celeron powered mini pc with dual lan for the router. Normally I would build something myself but for the cost and the lower power consumption (I’m hoping my current 500 watt ups will support whatever I end up using for my next router) and the fact that it has dual lan, it looks like a good buy. But here’s my question if I get a network switch with 2 multigig uplink ports and the rest gigabit ports so that I can run multigig connections to my gaming desktop and my unraid server will I be limited by having only gigabit from my dhcp server? That is, if I connect the pfsense router to one of the gigabit ports will I get multigig transfer speeds between my desktop and my unraid server if they are connected to the 2 mutligig ports?
There’s many different options here, e.g. I just saw ancient j1900 based mini pcs still on sale today (cheap, but just not a good buy). Double-check/Consult with folks here once you find something.
Only traffic going through the router will be limited to gigabit link speed. Traffic on the same switch and on the same subnet (e.g. 192.168.1.2/255.255.255.0 ↔ 192.168.1.3/255.255.255.0) won’t be going through the router (just to switch and back), so router port link speed doesn’t matter, even if it is also on the same subnet/switch as the desktop and unraid server.
Also, btw, you could run e.g. openwrt or pfsense in an unraid vm - chances are you’d be less limited by compute than with a separate small Celeron box (but it depends on the unraid hardware and setup and which Celeron box)
Thank you. That answers my question perfectly. I’ll consider the unraid option, but at the moment I have a stability issue there to work out. I think it’s a problem with the 6.9 beta release of unraid but I can’t test it on 6.8.3 because the driver for my mobo’s built in 2.5g nic isn’t present in 6.8.3.
I’ve got a Qotom Q350G4 from AliExpress, it has 4 gigabit NIC’s, and works awesome with PFSense.
with 4GB RAM and a core i5 4200U. it’s way overkill and runs everything perfectly.
I’ve got 3 subnets running and multiple VPN’s and services.
It’s extremely stable, would recommend.
edit; it also supports AES-NI
