Does anyone know the current plans for NTSync?
The last update that I found on this was that it’s disabled in the 6.10 kernel and if you want to enable it, you have to build the kernel yourself and then use a patched wine version to get it running (i.e. wine-tkg). Then I found in the mailing list someone asking for a review of the patch, but that was almost 2 months ago.
Does anyone have any more recent info and maybe knows if this is set to be enabled by default in any near future kernel versions (i.e. 6.11)? Because I’m afraid of building and installing custom kernels on my main PC in case something goes wrong, but I have a CPU bound game that I think will benefit from this (it actually performs worse with fsync or esync than without either of those, but the “correct” implementation that ntsync is aiming to be I hope would lead to an improvement instead).
You shouldn’t be, just don’t make it your only kernel.
Keep your distro’s stable kernel installed, build your kernel, and if there are problems fall back to the stable one to diagnose.
