Does anyone know if and how i can enable a HD6670 and a GTX460 on my GA-A75M-S2V ?
------------------ System Information ------------------
Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-A75M-S2V
Processor: AMD A4-3300 APU with Radeon(tm) HD Graphics (2 CPUs), ~2.5GHz
You probably can't; the 2 contrasting drivers would cause so many errors, it wouldn't be worth it.
i wanted to use one for bitcoin and the other for gaming :/ i have them both installed atm but only the HD 6670
is showing.
Yes you can, but you CANNOT install either drivers, you have to live with the stock Microsoft VGA drivers.
So it won't work for mining.
well now i have to try to get the gtx working it wouldnt even turn on the screen in another computer.
