My wild guess as to how Apple does it is that they have iTunes produce a database of synced songs and push that database to the phone, which uses the same database. So any form of discovery isn’t needed on either side except when iTunes looks in the folders for songs, but then it just adds them to its database.
I’ve seen people having issues with extremely large music libraries on Android. We’re talking over ten thousand items with many 100+ song playlists.
The goal is to make the process this simple:
- Dump music into directory that the library manager program can see.
- Create playlists in library manager program of those songs.
- Set playlists to sync to phone.
That’s it. No directory management. No file management. No swapping out SD cards.
The problems that have come up when trying to do this on Android are the following:
- Sync time when 1 change is made in a 10,000+ item list due to scanning for changes rather than using a database.
- Managing the playlist for syncing on Windows in most programs feels like using very old software.
- Android having to discover the songs are there by scanning its own music directory.
iTunes fulfills half this process, but solving it for Android’s side is the hard part, both for syncing and discovery, if you do use iTunes.
Does anyone have obvious solutions I’m missing for this?
I’ve found programs that sync iTunes to Android (MusicBee, iSyncr, doubleTwist, etc), but none that make use of a database on the Android side for discovery.
I imagine that’d be more so the music player app, but that’d mean it’d have to be able to utilize the same database the syncing app uses. And that’s where I’m personally stuck.
I had thought that syncing the playlists themselves would work as a database. i.e. I open a playlist. The playlist has 100 songs in it. None of them are ones I’ve opened before so the music app wasn’t aware of until now, but having the playlist tells the music app they’re there.
I doubt that’s bullet proof though.
