Doen AMD GPU's have Radeon Boost, Anti-Lag and Enhanced Sync?
I wonder if Radeon Boost, Anti-Lag and Enhanced Sync are available in APDGPU-Pro or FOSS drivers
Anti lag is not supported on DX12, Vulcan or OpenGL only DX9 and DX11
which means no support for linux
Enhanced Sync is configurable from the overlay, so it might be possible, but probably unlikely in the open source driver unless there is a gui option, you might be able to do some command line magic if its documented
https://www.amd.com/en/technologies/radeon-software-enhancedsync
