Do you think it is worth to wait for Broadwell?
Since I wanted to upgrade my rig before the end of January, I started wondering if it wasn't actually better to wait for Q2-Q3 and see the new Intel CPUs coming out. What do you guys think?
Move to CPU section.
Yeah, Broadwell is Intel's 'tick' cycle where they do substantial improvements instead of more incremental like Haswell. I'd wait if you are patient.
that would depend entirely on what you have now and how antsy you are to upgrade
also broadwell is a tock, it's (as far as we know) just a die shrink
I thought tick was the die shrink.
http://en.wikipedia.org/wiki/Intel_Tick-Tock
This is what I have. (The GPU is a Sapphire 6950hd 2GB)
And this is my PSU. Do you think I should wait?
Even if it is a tock, Intel has been know to really beef up there processors features or even tweak/enhance the existing architecture, like they did with Sandy Bridge to Ivy Bridge, I've also heard Broadwell will start to support DDR4 (I'm not talking full support but maybe partial support)
Your power supply will be fine, die shrinks usually reduce power consumption and TDP
So  you're saying I should probably wait? Also, I forgot to say that that PSU is 2 or 3 years old, don't know if it's relevant.
Its up to you, but if it were me, I would wait until after CES and see if Intel teases any new features or performances. If you don't see anything you like, go with haswell or wait longer to see if anymore information surfaces, but if you like broadwell wait till release
I see. Well then, thank you for your time!
