Do We Even Need Mousepads?
Here is the thing. not popular opinion is that mouse pads are useless because they have been invented for Ball mice.
I really don't know how aboutthat.
So I'm asking your opinion. Do We Even Need Mousepads?
Here is a bit info.
http://www.tomsguide.com/us/mousepad-surface-mice,review-1538.html
http://www.tomsguide.com/us/mousepad-surface-mice,review-1538-21.html
https://www.ehow.com/about_5538230_laser-mouse-need-mouse-pad.html
We really don't but it is just more comfortable to use them then to not to use them.
Back when i used to go to lans to play counter-strike a mousepad was a must have. It provided me with a consistant surface that i was used to, which to me was important. Still use my qck+ and loving it.
Select your desk on mousepaddiness. Just one, giant mousepad.
Best Idea ever or get a bunch of mouse pads and glue them to the desk.
With a mouse pad I can remove it from the desk and clean the desk from various spills and munchie stuff. The pad just needs a simple wipe and it is ready to go if I don't feel like cleaning the entire desk. Hense, I stick to the pad.
I totally agree. It's mouse movement on surface not a precise cursor movement on software.
Beside even a laser mouse it can be worst experience. Simply because of texture is on the pad can be really colorful and it can mess with a cursor movement on soft it self.
