Short version: after installing an MSI tpm on my MSI motherboard, my graphics card uses default windows drivers for about 30 seconds after booting into Windows 10 (if I open Device manager quick enough I see the triangle next to the GPU entry), after which it is eventually detected correctly and works normally after a boo-boop and screen flicker.
My googling hasn’t turned up anything relevant yet. Is this a Windows 10 thing or a motherboard thing? I can’t imagine this is normal behavior.
Well i can’t speak to TPM causing it but I’d agree that is not normal behavior. I do wonder though if I’m not experiencing something a little related, as my motherboard began making the “no VGA” error beep after enabling TPM (that was not the only change, it was a complete re-install). After a few seconds the bios seemingly decides there is a VGA installed after all and continues booting.
Updating your DirectX manually might solve it, I remember back in the old days(TPM 1.0) if your drivers changed the DX subsystem needs to “refresh” the signed drivers status. Factoring in all the breakage of 10 lately, something legacy could of been borked.
I know with my system that if I don’t have my display turned on first my motherboard throws a beep code for the display adapter. The screen will be blank until I get the prompt to log into the os. Yes I do have the devices all up on current bios and the issue is with this motherboard as it will not work with a gigabyte 1060 or 1080 card.
Just to confirm, I disabled TPM in the bios and the behavior persisted. Only after the module was physically removed did the behavior revert to normal (gpu detected correctly at boot).
In the in between time I updated my BIOS to the latest from MSI’s website, which did not change the behavior.
I wonder if the MEG x299 Creation just has borked TPM support.
There are some GPUs that have lousy EFI support due to custom “clocking BIOS to push higher GPU/VRAM clocks outside of Nvidia/AMD reference specs”, ASUS did this on their early EFI supported Radeon GPUs and you’d get a random boot failure/boot loop.
Hopefully this issue has been resolved. It’ll be a few years before I upgrade my mobo / cpu / memory again. Be nice to upgrade the gpu but prices are still out of my price range!
