Do SSD's save power on laptops?
i recently bought a refurbished asus laptop. It is a lower end ultra book with a 635M. IT comes with a 32gb SSD for OS and a 500gb HDD at 5400rpm. The laptop has horrible battery life (around 1.5hr when gaming) and i was wondering if changing the HDD to a SSD would increase battery life. Also, if you know any other battery saving hardware then can you please help.
If you Help then thank you :)
Disable the discrete gpu first of all for more battery life. If you're gaming then there is no way around that - the gpu wants lotsa juice.
Things that may help.
Decrease the brightness (biggest drain on a battey). Turn off shit like bluetooth etc. Go to the power settings and set the cpu up correctly for battery life - low max frequency etc.
The power saving is very negligible going to a full ssd.
