------------------------LG UHD 4K LED TV (55UH6030)---------------------
DO LED TV's have a break-in period? like plasma TV's?
I turned my new TV on last night and it was super dark! i think it got better after about 2 hours of use but i couldn't tell for sure if it was just my eyes getting used to it or not?
If they do need a break in period should I just leave brightly colored cartoons on for a few hours or should I download a color loop or just use it as a I normally would?
this is the first "Good" TV I've ever owned and i don't want to mess it up!
DId you go through the settings and see if you can turn up the brightness? Some TVs have power saving settings that will automatically dim/brighten the screen depending on the ambient light, look for this in the settings as well. Actually, just open up the users manual and see what all is available.
I did, I turned of "power saving mode" & "Eye strain protection" & I flipped through the presets, the only one that made any difference was "VIVID" witch did brighten it up just a hair but i could not find a direct brightness scale setting =(
Most of the time the picture setting in the box is set to look artificially VIVID when under store lighting next to a row of other TV's. All the manufacturers have non-accurate color initially, because a properly calibrated screen will look dull compared to an over-saturated screen right next to it on the shelf. Even my cheap TV looks pretty good once I adjusted it.
It does sound like your dim TV may be defective. I don't know. I have never heard of this problem before.
