I am looking to build a system for running SongShowPlus.
It will have 2 Blackmagic Design DeckLink Mini Recorder capture cards and 2 Gigabyte GeForce GT 730 2GB video cards (or simmilar) to get 4 video outputs.
Do I need socket 2011 for the PCIe bandwidth (and maybe RAM bandwith?) or is socket 1150 fine?
I am looking at either a i7 4820K (2011) or i7 4790 (1150).
This computer will be playing video files/ppts, capturing 2 HD video streams, outputting to 4 different screens and possibly live streaming (if our internet connection will handle it) all at once.
Just for some extra info, SongShowPlus supports the DeckLink standard (with a plugin) which is supposed to reduce lag from the capture process and offload some of the text over live video processing.
Also worth noting is that GoFishMedia (parent company of SSP) sells prebuilt systems for this application but there is no info on what is in them (not even a photo of the back panel). They are very expensive (so is shipping to AUS) and have lots of features that we don't need. Also you void the warranty by adding/changing the hardware so we cant add other things like a firewire card for audio recording from the mixing desk.
Thanks in advance, Hobgoblin.
