Do I have to reinstall my OS after exchanging my Mobo and CPU?
Hey guys , i will get a AM3+ Board and a FX 8320 for christmas ( probably :P) and i was wondering if i have to reinstall my OS after that.Im using Windows 7 currently , and it would be a pain in the arse to re-download all my Games and Applications , because my  blazing fast Idownload speed of 320 Kb/s will take 8 hours to download TF2 :c. Anyways. I hope youll give me some answers , and no , i do not own asecond Hard Drive,
No, because the OS resides on the storage unit (Hard Drive/ SSD.)
If you're currently using an AMD board then it might work, you can try it out, but it will probably be buggy or not work at all. Generally you should reinstall the OS if you change the board, but there can be ways around it if you really can't.
Not sure about the CPU, but if you uninstall the drivers, a motherboard switch should be fine.
I changed my motherboard yesterday, and I just needed to re-enter the windows key.
Try to get  an SSD for OS.
Im currently using a AMD Athlon x2 220 . It´s using a AM3 board. That´s all i can tell , because it´s oem :P
It really depends. Some times the drivers and such will link up no problem and you won't have any issues. I've  swapped out a 9600 GT for my current GTX 570 and even though they use the same driver it still bricked the OS and i had to do a fresh install.
So, If you're using components that use the same driver package to run then it SHOULD. But it doesn't always work out that way sadly.
