Do I have enough power to add another GTX 660 to my rig?
Specs:
CPU: AMD FX 6300
PSU:  600w bronze EVGA
RAM: 8GB DDR3 RAM
GPU: MSI GTX 660
HDD: 1TB mechanical
5 USB devices
Thinking about buying another 660. Wasn't sure if my PSU can handle it.
Thanks
I believe you do. 660 doesn't draw a ton of power so the 600 watt PSU should be enough for them.
Thanks, appreciate it
Each 660 should only draw about 150W during gaming. I'm confident you could squeeze a second GPU in there.
600w should be more than enough so you'd even be I'm the clear to do some overclocking my friend.
Cool, thanks guys. Maybe I can get acceptable frame rates in Metro Last Light XD
you will, I have 2 660s and went through the whole thing maxed out
Yes It's good. I was first concerned about amps on the 12V rail but your has a strong single Rail. You're good!
