I'm pretty sure that my 2GB of ram is a bottleneck, but is there anything else I should replace?
Get an SSD. Even a cheap small one could make the system feel like new.
EDIT: what this guy said ^^^
I just notice the 64-bit OS. lol
Well, it all depends on what you do.
However, if you want to bring your whole system up to snuff with your 7700 GPU then you have 2 glaring chokepoints.
1.) Yes, your Ram (Why do you have 64-bit operating system with only 2 GB is beyond me XD) which is limited in capacity as well as speed seeing as its 2gb of 800 GHZ DDR2
2.) Your CPU (and motherboard as well) are pretty old now.
So, if you're thinking of upgrading your system to a more modern level you'll be better suited upgrading your Mobo, CPU, and RAM to current standards. FM2 and 1150 will be supported for the next generation of processors so they're decently future proof.
Upgrading just your DDR2 Ram will get you by for now but if you want to bring your system up you'll need to update your platform. Otherwise, you'll just be wasting money.
