Do all GPU's Work?
Do all GPU's work for every build?
Here is my build:
CPU: AMD x6200 zambezi
MOBO: Gigabyte  GA-880GM-USB3 AMD 880G HDMI USB 3.0 micro ATX AMD motherboard
GPU: HELP ME! I would like to game in MAX settings. Any ideas?
Hard Drive: SeaGate 500GB mechanical hard drive
Memory: 16GB DDR3
Power supply: 600W corsair bronze certified
What CPU should I purchase for 200-300 dollars; also what is the best tower to buy? Should I get a new MOBO?
What is your budget?  You may be best off looking at one of their $XXX Rig videos they make every month or so to get ideas for whats good for what.
Also, any GPU that fits the PCI-e lane will technically work.
if you are going to use this for gaming then you wont need more than 8gigs of memory..
im kinda asuming that you mean "GPU" in the part of your post..? becasue you shouldnt use that much on the CPU in a budget gaming build..
anyways, get the best one you can afford from this list:
http://www.anandtech.com/bench/GPU12/372
