DNS probe finished no internet issue
Hi all,
i'm having an issue with getting on the internet after a power outage. I've tried uninstalling the network adapters then letting windows reinstall them. System restore. Can't access TCP/IPV4 properties its not enabled then I tried enabling it via cmd line didn't work. Restarted my modem as well. Also ran malware bytes + various malware tools to see if there was any malware causing the problem, no luck. using windows 7.
edit: also did safe mode with networking same issue.
Any ideas?
Control panel > Network and internet > Network and sharing center > Change adapter settings > select your adapter > properties > enable ipv4
Still nothing.
Go into your router settings make sure your 'obtain ip address from isp' is on, and that your dhcp is correct for your provider.
I can get on my internet just not with my desktop, currently on laptop.
