Do you think 737414-001 HPE Cable Management Arm Kit will compatible with HP DL380p G8 ?
AFAIK the arms are hooked to the rails, not the chassis. So as long as the rails fit, the arm should fit too.
Be aware the arm blocks airflow, a lot.
