Diy aio
Hey tek,
this company http://www.cratecomputers.com/collections/computers/products/cc1g sells upgradeable all in one PC's and wanted to do somthing like that with some of the stuffs i already have and make myself.
does anyone know a case that can fit a full system with a GPU that i can mount to the back of a monitor?
mount a 30lbs system on a 15lbs monitor?
no
You're thinking about it wrong. You want to put a monitor on a case. That would be much easier and more sound. Absolutely doable
Are there any products that have this type of functionality? or do i go to the fabrication shop?
what do you mean?
all you need is to put a mount on the side of a computer case
http://www.displays2go.com/P-24115/VESA-TV-Mount-with-Tilting-Features?utm_source=google.pla&utm_medium=cpc&utm_campaign=GooglePLA&gclid=Cj0KEQjwh428BRCnvcyI-5nqjY4BEiQAijebwhS4uXbrjWUyB1Z6Hsxz94OzW4dMF8zsLwpE0dTqHtIaApPC8P8HAQ
something like this with some good blots and washers and done
gives you tilt as well
sounds easy enough, will post a new thread if i build it
Thanks guys
