Hi All,
you may remember me from couple of months ago, complaining about my dell studio unable to run clean win7 + skype.
Clean reinstallation did help that day, but I'm in the same situation today.
It's enough, this time, however.
I would like to switch to linux.
Could you recommend some distro to me ? I have practically no experience with linux machines.
Ubuntu might seem sufficient, there is one problem however.
I have ATI Radeon HD4570 in that laptop. With opensource driver, the gpu is overheating and fans spinning all the time.
Putting Legacy catalyst driver 13.1 there helps, but that sets me back to Ubuntu 12.04.1 LTS.
Please find other specs of my laptop below:
- Core2Duo P8600 /2,4GHZ, 1066Mhz, 3MB)
- Intel Wifi Link 5300
- Ati Radeon HD4570
- 2x2048MB ram 800mhz
- Bluetooth Dell 370 Card
- 1366x768 primary screen
I don't consider other specification that important, if you are curious, don't be shy to ask.
Now to expected workload:
- web-browser
- spreadsheet / documents processing
- minor java - netbeans, jsf development - (I am beginner)
My win7 installation can't handle this unfortunatelly.
Please do not advise me to swap gpu, or buy more ram. That laptop is 7 years old, 8gigs of ram would cost me over 200 €, which is more than half of price of new nuc, which would be suitable for me.
Is there anything I could do with the machine to return it back to life ?
Or should I finally ditch it and buy a nuc instead ? (Mobility isn't concern, while size is)
Any recommendations ?
Thanks guys :)
