Display signal quality issues, looking for input
I’m having issues with my work laptop’s thunderbolt dock and the L1 KVM… I suspect it’s a displayport signal quality, because of the following:
Signal route Status
onboard DP → KVM → display it’s fine
USBC/TB port → display It’s fine
onboard DP → display it’s fine
TB → Belkin dock → display it’s fine
TB → Belkin dock → KVM → display no bueno
TB → WD16 dock → display it’s fine
TB → WD16 dock → KVM → display no bueno
Now the display is the LG 38WK95C-W which runs at 3840x1600 native. If I crank the resolution down to 1920x1080, everything works perfectly fine. I also get warnings from the monitor once in a while saying “only use the included displayport cable”
I’m using the dell cables that Wendell sells on the store/with the KVMs, so I know they’re good quality, but I’m curious if anyone knows of good quality cables that are shorter than the ones he sells? I’ve got a 36in thunderbolt cable that I suspect is bringing the total signal run far enough that it degrades the quality.
I’ve tried those DP repeaters from the store, both before and after the KVM, and they do not help. Any suggestions?
I’m open to trying out the L1 USB C KVM, but only if it charges the laptop.
I’m also open to the possibility that the thunderbolt cable is of poor quality, and am willing to try replacing it, but I don’t know what cables are any good. Looking for suggestions on that front.
Oh, right. Symptoms are as follows: Intermittent display blanking, not waking from sleep and “salt and pepper fight” across parts of the display (this might be the GPU, but I’ve been able to reproduce it on multiple distros with multiple variants of the nvidia driver, open and proprietary)
At this point, I’m open to literally any suggestions; been fighting with it since mid-may. Laptop is a Lenovo P1 G3, i9-10885H, Quadro T2000.
I have a Dell TB dock that was fine for months but recently decided to never work again with the KVM, even with a repeater. Idk what the deal is. Might try the Lenovo one next time I have a few hundred $ to burn. All my cables are over-spec’d at DP1.4.
I know none of that helps you, just figured I’d pile on.
Yeah, my dell TB dock is probably the same one you’ve got, that ugly square thing with the hard-wired thunderbolt cable? Goddamn thing worked better before the firmware update, and even then, it was quite hit or miss.
I think it’s Lenovo’s lazy thunderbolt implementation, tbh. Damn thing is going through the nvidia gpu which means I can’t have it off while I’m docked.
Oh yeah it is, and I did just update the firmware.. damn it.
How long are your cables?
I think 0.5m quality cables would work.
Where is that suspected Thunderbolt cable in the chain of devices? Since Thunderbolt reencodes / compresses Displayport Signals, it should basically be redriving the Displayport signals, so that the cable used for an actual Thunderbolt connection to a dock should have no influence on Displayport integrity (except if the Thunderbolt connection itself would be unstable, but I would hope that this would be obvious if the case)
Have you also tried the Thunderbolt output of the Dell dock? I’ve had many problems with my 38" Monitor attached to the Displayports coming of the MST-Hub inside the dock (although I have the WD19TB and those problems resulted in me not being offered the higher resolutions at all).
I would actually like that better, because that allows for DP 1.4, which the iGPU does not have. (My Monitor requires that for full refresh-rate as it does 120Hz + 10Bit)
But in your case that could actually pose a problem if you ever have a DP 1.4 capable monitor. In my experiments, an Alpine Ridge Thunderbolt-Controller (as in your Dock) did not make it known that it only supports DP 1.2, and connecting a DP 1.4 Monitor and GPU through it resulted in an endless loop of reconnecting and black-screen, as the GPU seemed to attempt a DP 1.4 connection, but failing in a different way than when just using an older cable.
1m thunderbolt. All displayport are 2m. so with the KVM in the mix, it’s 2x2m(DP)+1m(TB)
Front of the line. Laptop → TB cable (1m) → TB dock → DP cable (2m) → L1 KVM → DP cable (2m) → display
Hmmm, I actually haven’t. Will do.
Another part of the issue is that I’m stuck on Ubuntu 18.04, kernel 5.4.0-74 due to work restrictions right now. Not sure if there’s something in there that’s causing a problem, but I’m on the proprietary drivers, so I figure it’s probably okay. This isn’t something I can fix/bypass, work has stupid restrictions that I’m pushing back on, but that’s about all we can do.
What typically happens on my system is that I have to initialize the display at 1080p, then I can crank it up to 3840x1600@60, once I get the 1080p config to display. going from display-off to 3840x1600@60 is a coin flip in terms of the display getting the signal.
Welp, on a hunch, I plugged my personal laptop into the chain and it seems to be working just fine. Although, this one’s running wayland, so I’m not sure it’s a fair comparison.
I’ll have to see if I can dd my personal machine over to my work laptop real quick to do some comparisons.
EDIT: nope, wayland still has the problems… Just lucky first try.
It seems like link training fails.
Maybe the laptop during 4k link training leaves the amplitude and pre-emphasis at a low level?
Possibly. I wonder if there’s a driver flag that can be set to crank it up…
Why would the laptop’s output effect the signal strength of the TB-docks’ outputs?
I know that Thunderbolt 3 tunnels PCIe and DP, but at the dock/hub where it demultiplexes the two, I would imagine it creates a new DisplayPort signal. It does not just passively map pin N on the incoming USB type C port to pin X on the outgoing DisplayPort connector… right?
Even if that is how it works, there would still be a redriver for the DisplayPort output, right? So are not the main suspects the Thunderbolt docks? Should not their outputs be just as good as those on the laptop?
I came across this PDF from Texas Instruments; USB Redriver and Type-C Solutions; but I am not well versed enough in electrical engineering to answer my questions from it, but perhaps it will be of use to you.
Yes, I was assuming that the dock was passively passing through the dp signal.
The MST-Hubs inside the docks are active components that are visible to the host GPU.
In the past, I’ve had problems with daisy-chained setups (so basically an MST-Hub inside the first monitor, just as in the docks).
With the exact same devices and cables, Windows had a totally reliable connection to both displays, but under linux (on the same damn machine) the second monitor would sporadically glitch out (although it never reduced resolution, just momentary black-outs and errors).
This only makes sense to me, if the GPU has control over the link-training etc. of the MST-Hubs’ connections, otherwise I do not see how windows and linux could behave differently. So there could very well be knobs a driver could turn. But I have been too lazy to go looking for confirmation in the DP spec.
I only ever tested / saw this on Intel iGPUs (for lack of PCs running linux with non-intel graphics & DisplayPorts) and I have not seen this since Fedora 34, but I mainly boot up linux on bare metal for fun and to check the progress of linux on desktop for my use cases, so it might not have been running for long enough to exhibit the same problem.
Oh, I manually set a lower resolution to test. It was fine at the lower resolution, so I thought it’d be interesting info to share. This wasn’t an automatic thing.
In all fairness, I’m still on old software, so I might need to just get on kernel 5.12 and I’ll be good. I have no idea, but until I’ve vanquished the cylance demon from my machine, there is no recourse.
I’ve now skimmed through various chapters of the DP spec, but found nothing but a headache…
It certainly reads like each component is responsible for its own downstream link-training, and the only control the GPU/driver may have, is which options it will attempt for the first hop, and when it will downgrade the bandwidth due to too many errors.
Neither seems to fit your problem.
Have you already tested with the TB-out of the docks? My hope would be, that the problem ist somehow related to the MST-functionality, which would be sidestepped, by connecting to the TB-out directly.
nope. Fuck it, let me try that now. I’ve got a C cable i’m using to charge my personal laptop that’s 2m, so I’ll hopefully see a problem if it shows up.
So my TB out on the dock apparently doesn’t handle a display signal.
Maybe the dock’s type-C output is not Thunderbolt, but merely USB-only? Does its manual specify?
Also, are you sure the cable is a TB cable and not USB-only?
I took some time to do some research, and… I still have no idea whether if USB 3.1 Full Featured cables or only Thunderbolt 3 cables can carry a type-C DisplayPort alt-mode signal. I did find this helpful blog post from people.kernel.org, but sadly it is not helpful enough:
Looking at the USA manual for your 38WK95C-W monitor, it does specifically state:
PD (Power Delivery), DP Alternate Mode (DP over USB-C) and USB Data are
supported via USB-C Port.
https://www.lg.com/us/support/manuals-documents?customerModelCode=38WK95C-W&csSalesCode=38WK95C-W.AUS&category=CT10000030&subcategory=OTHERS
So just throwing this out there, you think a cheap displayport amp/extender would solve this issue?
Was this supposed to be a joke, because I had to actually laugh out loud!
