I have been overclocking my GPU for some time now and just recently have come across an issue regarding my display. It boots up and everything just fine, but once I type my password to get to the desktop, it flickers off to a black screen after showing the desktop for maybe a millisecond. I CAN still access it in safe mode, but if the overclock I put it under is the issue then I don't know how to fix it in that mode, since the program doesn't even recognize a card being in there.
Now, regarding the card, it is an Asus R9 290 and the software I used was MSI Afterburner. The OC that was set was 1115 mhz on the core and 1475 on the memory. I ran firstrike to make sure it was stable and then played some games for an hour or two. I didn't run into the problem until the next day when I tried booting up.
So... Did I just overdo it and fry the card or could it be something else?
I can't get afterburner to run properly in safe mode as it doesn't show any of the OC profiles I have, or even that I have a card installed. Unless there is a way in my BIOS to get to the gpu settings, I'm out of luck. And I do not believe there is a physical BIOS switch on the card either
No, I looked for a BIOS switch and it didn't have one. HOWEVER, I guess I did a manual reset or something because when I unplugged then replaced it in my rig it was just fine. So it is definitely fixed now :) thanks everyone for the help!
