Does something like lxde on x11 produce the same issue? does lightdm work at all? how about directly invoking startx to run lxde?
Can you remove libseat from the environment? Just to eliminate it as the culprit.
should be noted: system graphics is an AMD Phoenix (which is just Navi 34) IGP, unknown model of display adapter, unknown model of laptop.
the more significant error here is “amdgpu: amdgpu_cs_ctx_create2 failed. (-13)”, which i have only seen before when dealing with gamescope, which is why i suggest testing some simple X11 DE without compositing, as i suspect the issue is somewhere withing OP’s wayland+libseat setup.
if the wayland+libseat is indeed NOT the problem, then the display adapter driving connector ‘eDP-1’ is defective or buggy. assuming no underlying kernel or amdgpu/mesa bug is responsible.
irrelevant ranting:
2880x1920 @ 120hz 24-bit color over a single displayport connection is a goofy thing to do.
