Hi Everyone,
Sorry that my first post is a cry for help, I have been following level one and Wendel and the team for some time I am think you guys might be the ones to help…
Ok so the issue,
I have 4 SAS 4TB DELL branded enterprise drives. they report in the LSI MSM software as Toshiba MG04SCA40EN ( have updated the firmware to the latest version btw.)
I hook these drives up to one of a number of different Raid controllers, being
DELL H700 I have 2 of these one with BBU and one without, but both with 512MB cache.
LSI 9260-16i
LSI 9260-8i
DELL H200-8i
This is all inside a Sun Ultra 27 case with the 4 way SAS built in backplane, (The back plane has also been replaced with a spare.)
The rest of the sytem is a ryzen 3700X 32GB RAM and an gigabye X570 AORUS ULTRA which has 3 16x physical PCI-e slots. it also has SSD’s attached to the onboard SATA and 1 NVMe drive for booting. I have also tried the Raid controller in the bottom and middle slots. The SAS backplane have 1 molex connector for powering the backplane. lastly there is a 750watt superflower PSU.
I am constantly losing a drive from the array and its not always the same disk, I have 1 spare disk which I have also swapped in and out to replace what ever drive disapears from the array.
I can’t upload files yes so I can take a sample and poasted it below
Any suggestion gratefully recieved
Summary
MegaRAID Storage Manager 17.05.02.01 Event Log - Generated on Wed May 05 21:40:10 BST 2021
ID = 113
SEQUENCE NUMBER = 296768
TIME = 05-05-2021 21:32:55
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x38 0xfb 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x22 0x23 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 296767
TIME = 05-05-2021 21:24:56
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x03 0x28 0x93 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x22 0x22 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 296766
TIME = 05-05-2021 21:18:31
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x01 0x52 0x1c 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x22 0x21 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 296765
TIME = 05-05-2021 21:13:47
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x88 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x29 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x88 0x55 0x07 0x01 0x00 0x57 0x82 0xbc 0xb0 0x55 0xf1 0x89 0x02 0x57 0x82 0xbc 0xb0 0x55 0xf1 0x89 0x02 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 296764
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x88 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x26 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x88 0x55 0x07 0x01 0x00 0x57 0x82 0xbc 0xb0 0x55 0xf1 0x89 0x02 0x57 0x82 0xbc 0xb0 0x55 0xf1 0x89 0x02 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 370
SEQUENCE NUMBER = 296763
TIME = 05-05-2021 21:13:26
LOCALIZED MESSAGE = Controller ID: 0 VD is available. VD : 0
ID = 138
SEQUENCE NUMBER = 296762
LOCALIZED MESSAGE = Controller ID: 0 Created VD: 0
ID = 249
SEQUENCE NUMBER = 296761
LOCALIZED MESSAGE = Controller ID: 0 VD is now OPTIMAL VD 0
ID = 114
SEQUENCE NUMBER = 296760
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:3 Previous = Unconfigured Good Current = Online
ID = 114
SEQUENCE NUMBER = 296759
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:2 Previous = Unconfigured Good Current = Online
ID = 114
SEQUENCE NUMBER = 296758
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:1 Previous = Unconfigured Good Current = Online
ID = 220
SEQUENCE NUMBER = 296757
TIME = 05-05-2021 21:12:59
LOCALIZED MESSAGE = Controller ID: 0 Foreign Configuration Cleared
ID = 218
SEQUENCE NUMBER = 296756
TIME = 05-05-2021 21:12:56
LOCALIZED MESSAGE = Controller ID: 0 Foreign Configuration Detected
ID = 44
SEQUENCE NUMBER = 296755
TIME = 05-05-2021 21:12:21
LOCALIZED MESSAGE = Controller ID: 0 Time established since power on: Time 2021-05-05, 21:12:21 115 Seconds
ID = 10000
TIME = 05-05-2021 21:12:33
LOCALIZED MESSAGE = Successful log on to the server User: ross woodall, Client: 10.0.0.1, Access Mode: Full, Client Time: 2021-05-05,21:12:33
ID = 44
ID = 227
SEQUENCE NUMBER = 296754
TIME = 68 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Controller Hot Plug detected
ID = 131
SEQUENCE NUMBER = 32069
TIME = 05-05-2021 20:47:26
LOCALIZED MESSAGE = Controller ID: 0 Unable to access device PD -:-:1
ID = 236
SEQUENCE NUMBER = 32068
LOCALIZED MESSAGE = Controller ID: 0 Drive is not certified: -:-:1
ID = 247
SEQUENCE NUMBER = 32067
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Disk Device Id: 1
ID = 91
SEQUENCE NUMBER = 32066
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: -:-:1
ID = 268
SEQUENCE NUMBER = 32065
TIME = 05-05-2021 20:47:08
LOCALIZED MESSAGE = Controller ID: 0 PD Reset: PD = -:-:0, Critical = 3, Path = 0x50000397982AE6C6
ID = 268
SEQUENCE NUMBER = 32064
TIME = 05-05-2021 20:46:27
ID = 268
SEQUENCE NUMBER = 32063
TIME = 05-05-2021 20:46:23
ID = 54
SEQUENCE NUMBER = 32062
TIME = 05-05-2021 20:45:49
LOCALIZED MESSAGE = Controller ID: 0 Policy change on VD: = 0 Previous = Current Read Policy: Always Read Ahead;Current Write Policy: Write Back for failed or missing battery; Current = Current Read Policy: No Read Ahead;Current Write Policy: Write Back for failed or missing battery;
ID = 114
SEQUENCE NUMBER = 32061
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:1 Previous = Failed Current = Unconfigured Bad
ID = 252
SEQUENCE NUMBER = 32060
LOCALIZED MESSAGE = Controller ID: 0 VD is now OFFLINE VD 0
ID = 323
SEQUENCE NUMBER = 32059
LOCALIZED MESSAGE = Controller ID: 0 Controller cache pinned for missing or offline VD: VD 0
ID = 81
SEQUENCE NUMBER = 32058
LOCALIZED MESSAGE = Controller ID: 0 State change on VD: 0 Previous = Optimal Current = Offline
ID = 114
SEQUENCE NUMBER = 32057
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:1 Previous = Online Current = Failed
ID = 248
SEQUENCE NUMBER = 32056
LOCALIZED MESSAGE = Controller ID: 0 Device removed Device Type: Disk Device Id: 1
ID = 112
SEQUENCE NUMBER = 32055
LOCALIZED MESSAGE = Controller ID: 0 PD removed: -:-:1
ID = 268
SEQUENCE NUMBER = 32054
LOCALIZED MESSAGE = Controller ID: 0 PD Reset: PD = -:-:1, Critical = 3, Path = 0x50000397982AE6C6
ID = 113
SEQUENCE NUMBER = 32053
TIME = 05-05-2021 20:45:47
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x03 0x00 0x00 0x00 0x40 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x4b 0x04 0x00 0x00 0x00 0x00 0x08 0x03 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32052
ID = 113
SEQUENCE NUMBER = 32051
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0xbe 0x80 0x00 0x00 0x00 0x08 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x23 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32050
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x1a 0x08 0x01 0x00 0xff 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x4b 0x03 0x00 0x00 0x00 0x00 0x08 0x1a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32049
ID = 113
SEQUENCE NUMBER = 32048
ID = 113
SEQUENCE NUMBER = 32047
TIME = 05-05-2021 20:45:46
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x1a 0x08 0x0a 0x00 0xff 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x4b 0x04 0x00 0x00 0x00 0x00 0x08 0x1a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32046
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0xa1 0x00 0x00 0x00 0x00 0x05 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x23 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32045
ID = 113
SEQUENCE NUMBER = 32044
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0xa1 0x00 0x00 0x00 0x00 0x05 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32043
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0xa0 0x80 0x00 0x00 0x00 0x15 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32042
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0xa0 0x00 0x00 0x00 0x00 0x15 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32041
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x1a 0x08 0x1c 0x00 0xff 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x4b 0x04 0x00 0x00 0x00 0x00 0x08 0x1a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x01 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32040
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x92 0x80 0x00 0x00 0x00 0x11 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x23 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 268
SEQUENCE NUMBER = 32039
ID = 267
SEQUENCE NUMBER = 32038
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = -:-:1No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x9e 0x00 0x00 0x00 0x00 0x07 0x00 0x00 , Sense = , Path = 0x50000397982AE6C6
ID = 267
SEQUENCE NUMBER = 32037
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = -:-:1No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x9f 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 , Sense = , Path = 0x50000397982AE6C6
ID = 267
SEQUENCE NUMBER = 32036
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = -:-:1No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x9e 0x80 0x00 0x00 0x00 0x0b 0x00 0x00 , Sense = , Path = 0x50000397982AE6C6
ID = 267
SEQUENCE NUMBER = 32035
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = -:-:1No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x92 0x80 0x00 0x00 0x00 0x11 0x00 0x00 , Sense = , Path = 0x50000397982AE6C6
ID = 113
SEQUENCE NUMBER = 32034
TIME = 05-05-2021 20:45:33
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x92 0x80 0x00 0x00 0x00 0x11 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32033
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x8c 0x80 0x00 0x00 0x00 0x06 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32032
TIME = 05-05-2021 20:45:30
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x26 0x3c 0x80 0x00 0x00 0x00 0x0f 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32031
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x25 0x92 0x00 0x00 0x00 0x00 0x09 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32030
TIME = 05-05-2021 20:45:29
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x25 0x18 0x80 0x00 0x00 0x00 0x08 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x23 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32029
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x24 0xbb 0x00 0x00 0x00 0x00 0x07 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32028
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x24 0x7c 0x00 0x00 0x00 0x00 0x06 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 32027
TIME = 05-05-2021 20:45:28
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = -:-:1Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x3b 0x24 0x2a 0x00 0x00 0x00 0x00 0x09 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x08 0x8a 0x55 0x07 0x01 0x00 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x58 0x42 0xb2 0xb0 0x42 0x97 0x22 0x03 0x00 0x00 0x06 0x00 0x00 0x00 0x00 0x00
ID = 370
SEQUENCE NUMBER = 32026
TIME = 05-05-2021 19:17:05
ID = 138
SEQUENCE NUMBER = 32025
ID = 249
SEQUENCE NUMBER = 32024
ID = 114
SEQUENCE NUMBER = 32023
ID = 114
SEQUENCE NUMBER = 32022
ID = 114
SEQUENCE NUMBER = 32021
ID = 114
SEQUENCE NUMBER = 32020
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:0 Previous = Unconfigured Good Current = Online
ID = 155
SEQUENCE NUMBER = 32019
TIME = 05-05-2021 19:16:49
LOCALIZED MESSAGE = Controller ID: 0 Battery relearn pending: Battery is under charge
ID = 220
SEQUENCE NUMBER = 32018
TIME = 05-05-2021 19:16:25
ID = 218
SEQUENCE NUMBER = 32017
TIME = 05-05-2021 19:16:21
ID = 114
SEQUENCE NUMBER = 32016
TIME = 05-05-2021 19:15:41
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:3 Previous = Online Current = Unconfigured Good
ID = 114
SEQUENCE NUMBER = 32015
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:2 Previous = Online Current = Unconfigured Good
ID = 114
SEQUENCE NUMBER = 32014
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = -:-:0 Previous = Online Current = Unconfigured Good
ID = 139
SEQUENCE NUMBER = 32013
LOCALIZED MESSAGE = Controller ID: 0 Deleted VD: 0
ID = 10000
TIME = 05-05-2021 19:15:16
LOCALIZED MESSAGE = Successful log on to the server User: ross woodall, Client: 10.0.0.1, Access Mode: Full, Client Time: 2021-05-05,19:15:16
ID = 44
SEQUENCE NUMBER = 32012
TIME = 05-05-2021 19:14:44
LOCALIZED MESSAGE = Controller ID: 0 Time established since power on: Time 2021-05-05, 19:14:44 300 Seconds
ID = 227
SEQUENCE NUMBER = 32011
TIME = 254 seconds from reboot
ID = 71
SEQUENCE NUMBER = 14836
TIME = 543 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Full initialization started on VD: 0
ID = 335
SEQUENCE NUMBER = 14835
TIME = 530 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 VD Bad block table is cleared. VD : 0
ID = 72
SEQUENCE NUMBER = 14834
LOCALIZED MESSAGE = Controller ID: 0 Initialization complete on VD 0
ID = 70
SEQUENCE NUMBER = 14833
TIME = 529 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Fast initialization started on VD: 0
ID = 73
SEQUENCE NUMBER = 14832
TIME = 521 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Properties updated on VD: = 0 Previous = Default Write Policy: Write Back;Default IO Policy: Direct IO;BGI: Enabled; Current = Default Write Policy: Write Through;Default IO Policy: Cached IO;BGI: Disabled;
ID = 335
SEQUENCE NUMBER = 14831
TIME = 418 seconds from reboot
ID = 72
SEQUENCE NUMBER = 14830
ID = 70
SEQUENCE NUMBER = 14829
TIME = 417 seconds from reboot
ID = 370
SEQUENCE NUMBER = 14828
TIME = 416 seconds from reboot
ID = 138
SEQUENCE NUMBER = 14827
ID = 249
SEQUENCE NUMBER = 14826
ID = 114
SEQUENCE NUMBER = 14825
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:11 Previous = Unconfigured Good Current = Online
ID = 114
SEQUENCE NUMBER = 14824
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:10 Previous = Unconfigured Good Current = Online
ID = 114
SEQUENCE NUMBER = 14823
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:8 Previous = Unconfigured Good Current = Online
ID = 4
SEQUENCE NUMBER = 14822
TIME = 396 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Configuration cleared
ID = 114
SEQUENCE NUMBER = 14821
TIME = 380 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:11 Previous = Online Current = Unconfigured Good
ID = 114
SEQUENCE NUMBER = 14820
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:10 Previous = Online Current = Unconfigured Good
ID = 114
SEQUENCE NUMBER = 14819
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = Ports 8-11:0:8 Previous = Online Current = Unconfigured Good
ID = 139
SEQUENCE NUMBER = 14818
ID = 73
SEQUENCE NUMBER = 14817
TIME = 232 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Properties updated on VD: = 0 Previous = Default Write Policy: Write Back for failed or missing battery;BGI: Enabled; Current = Default Write Policy: Write Through;BGI: Disabled;
ID = 73
SEQUENCE NUMBER = 14816
TIME = 177 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Properties updated on VD: = 0 Previous = Default Write Policy: Write Through; Current = Default Write Policy: Write Back for failed or missing battery;
ID = 149
SEQUENCE NUMBER = 14815
TIME = 64 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Battery temperature is normal
ID = 10000
TIME = 05-05-2021 18:55:48
LOCALIZED MESSAGE = Successful log on to the server User: ross woodall, Client: 10.0.0.1, Access Mode: Full, Client Time: 2021-05-05,18:55:48
ID = 149
ID = 389
SEQUENCE NUMBER = 14814
TIME = 31 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Host driver is loaded and operational
ID = 227
SEQUENCE NUMBER = 14813
TIME = 30 seconds from reboot
ID = 247
SEQUENCE NUMBER = 14812
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Disk Device Id: 35
ID = 91
SEQUENCE NUMBER = 14811
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 8-11:0:11
ID = 247
SEQUENCE NUMBER = 14810
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Disk Device Id: 34
ID = 91
SEQUENCE NUMBER = 14809
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 8-11:0:10
ID = 247
SEQUENCE NUMBER = 14808
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Disk Device Id: 33
ID = 91
SEQUENCE NUMBER = 14807
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 8-11:0:8
ID = 247
SEQUENCE NUMBER = 14806
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Enclosure Device Id: 245
ID = 91
SEQUENCE NUMBER = 14805
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: 245
ID = 167
SEQUENCE NUMBER = 14804
LOCALIZED MESSAGE = Controller ID: 0 Communication restored on enclosure: 1
ID = 266
SEQUENCE NUMBER = 14803
TIME = 10 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Board Revision: 20D
ID = 261
SEQUENCE NUMBER = 14802
LOCALIZED MESSAGE = Controller ID: 0 Package version 12.15.0-0248
ID = 141
SEQUENCE NUMBER = 14801
TIME = 09 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Battery Present
ID = 1
SEQUENCE NUMBER = 14800
TIME = 04 seconds from reboot
LOCALIZED MESSAGE = Controller ID: 0 Image version: 2.130.403-6221
ID = 0
SEQUENCE NUMBER = 14799
LOCALIZED MESSAGE = Controller ID: 0 Firmware initialization started: ( PCI ID 0x79/ 0x1000/ 0x9276 / 0x1000)
ID = 29
SEQUENCE NUMBER = 14798
TIME = 05-05-2021 18:49:54
LOCALIZED MESSAGE = Controller ID: 0 Hibernate command received from host
ID = 10001
TIME = 05-05-2021 18:34:25
LOCALIZED MESSAGE = Successful log out from the server User: ross woodall, Client: 10.0.0.1, Client Time: 2021-05-05,18:34:25
ID = 113
SEQUENCE NUMBER = 14797
TIME = 05-05-2021 18:33:56
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x06 0x54 0x37 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x22 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 195
SEQUENCE NUMBER = 14796
TIME = 05-05-2021 18:33:52
LOCALIZED MESSAGE = Controller ID: 0 BBU disabled; changing WB logical drives to WT, Forced WB VDs are not affected
ID = 149
SEQUENCE NUMBER = 14795
ID = 147
SEQUENCE NUMBER = 14794
LOCALIZED MESSAGE = Controller ID: 0 Battery started charging
ID = 10000
TIME = 05-05-2021 18:33:53
LOCALIZED MESSAGE = Successful log on to the server User: ross woodall, Client: 10.0.0.1, Access Mode: Full, Client Time: 2021-05-05,18:33:53
ID = 113
SEQUENCE NUMBER = 14793
TIME = 05-05-2021 18:33:39
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x06 0x58 0x9c 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 389
SEQUENCE NUMBER = 14792
TIME = 05-05-2021 18:33:28
ID = 227
SEQUENCE NUMBER = 14791
TIME = 05-05-2021 18:33:26
ID = 247
SEQUENCE NUMBER = 14790
ID = 91
SEQUENCE NUMBER = 14789
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 12-15:0:15
ID = 247
SEQUENCE NUMBER = 14788
ID = 91
SEQUENCE NUMBER = 14787
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 12-15:0:14
ID = 247
SEQUENCE NUMBER = 14786
ID = 91
SEQUENCE NUMBER = 14785
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: Ports 12-15:0:12
ID = 247
SEQUENCE NUMBER = 14784
ID = 91
SEQUENCE NUMBER = 14783
ID = 167
SEQUENCE NUMBER = 14782
ID = 376
SEQUENCE NUMBER = 14781
TIME = 05-05-2021 18:33:17
LOCALIZED MESSAGE = Controller ID: 0 Controller reset on-board expander
ID = 266
SEQUENCE NUMBER = 14780
TIME = 05-05-2021 18:32:57
ID = 261
SEQUENCE NUMBER = 14779
ID = 141
SEQUENCE NUMBER = 14778
ID = 452
SEQUENCE NUMBER = 14777
TIME = 05-05-2021 18:32:51
LOCALIZED MESSAGE = Controller ID: 0 Controller reset requested by host, completed
ID = 1
SEQUENCE NUMBER = 14776
TIME = 01 seconds from reboot
ID = 0
SEQUENCE NUMBER = 14775
ID = 451
SEQUENCE NUMBER = 14774
TIME = 05-05-2021 18:32:45
LOCALIZED MESSAGE = Controller ID: 0 Controller reset requested by host :
ID = 54
SEQUENCE NUMBER = 14773
LOCALIZED MESSAGE = Controller ID: 0 Policy change on VD: = 0 Previous = Current Read Policy: Always Read Ahead; Current = Current Read Policy: No Read Ahead;
ID = 22
SEQUENCE NUMBER = 14772
LOCALIZED MESSAGE = Controller ID: 0 Flash of new firmware image(s) complete
ID = 21
SEQUENCE NUMBER = 14771
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: bobm v25.05.04.00
ID = 21
SEQUENCE NUMBER = 14770
TIME = 05-05-2021 18:32:37
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: bobf v25.05.04.00
ID = 21
SEQUENCE NUMBER = 14769
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: BOOT v09.250.01.219
ID = 21
SEQUENCE NUMBER = 14768
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: BTBL v2.02.00.00-0000
ID = 21
SEQUENCE NUMBER = 14767
TIME = 05-05-2021 18:32:32
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: NVDT v2.09.03-0058
ID = 21
SEQUENCE NUMBER = 14766
TIME = 05-05-2021 18:32:22
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: BCON v6.0-54-e_50-Rel
ID = 21
SEQUENCE NUMBER = 14765
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: PCLI v04.04-020:#%00009
ID = 21
SEQUENCE NUMBER = 14764
TIME = 05-05-2021 18:32:12
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: HIIM v03.07.12.04
ID = 21
SEQUENCE NUMBER = 14763
TIME = 05-05-2021 18:32:05
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: BIOS v3.30.02.2_4.16.08.00_0x06060A05007/23/2014
ID = 21
SEQUENCE NUMBER = 14762
TIME = 05-05-2021 18:31:27
LOCALIZED MESSAGE = Controller ID: 0 Flashing image: APP v2.130.403-6221
ID = 10001
TIME = 05-05-2021 18:33:01
LOCALIZED MESSAGE = Successful log out from the server User: ross woodall, Client: 10.0.0.1, Client Time: 2021-05-05,18:33:01
ID = 113
SEQUENCE NUMBER = 14761
TIME = 05-05-2021 18:07:13
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xf2 0xf0 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14760
TIME = 05-05-2021 18:06:20
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xa7 0x8f 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14759
TIME = 05-05-2021 18:06:17
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xa6 0x97 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14758
TIME = 05-05-2021 18:06:16
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xcd 0xaf 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14757
TIME = 05-05-2021 18:06:09
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xc9 0x15 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1f 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14756
TIME = 05-05-2021 18:06:03
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0xc8 0x06 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14755
TIME = 05-05-2021 18:05:30
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x7c 0x9b 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14754
TIME = 05-05-2021 18:05:28
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x9d 0x84 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14753
TIME = 05-05-2021 18:05:24
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x9c 0x87 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14752
TIME = 05-05-2021 18:05:09
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x76 0x77 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14751
TIME = 05-05-2021 18:05:06
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x96 0xbe 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14750
TIME = 05-05-2021 18:05:04
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x05 0x96 0x5d 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1f 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 446
SEQUENCE NUMBER = 14749
TIME = 05-05-2021 18:01:04
LOCALIZED MESSAGE = Controller ID: 0 Transient error detected while communicating with PD: Ports 12-15:0:14
ID = 113
SEQUENCE NUMBER = 14748
TIME = 05-05-2021 17:58:26
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x04 0x6a 0xca 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14747
TIME = 05-05-2021 17:55:06
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x03 0xd4 0x5a 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14746
TIME = 05-05-2021 17:50:42
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x03 0x0f 0x48 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14745
TIME = 05-05-2021 17:49:47
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x03 0x01 0x37 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1c 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14744
TIME = 05-05-2021 17:49:22
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xf9 0x34 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14743
TIME = 05-05-2021 17:47:27
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xd9 0x25 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14742
TIME = 05-05-2021 17:47:15
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xd6 0xa5 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14741
TIME = 05-05-2021 17:47:06
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xd5 0x16 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1c 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14740
TIME = 05-05-2021 17:46:58
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xb5 0xde 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14739
TIME = 05-05-2021 17:46:47
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xb2 0xf5 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14738
TIME = 05-05-2021 17:46:38
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x81 0xcb 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14737
TIME = 05-05-2021 17:46:27
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x7f 0xba 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1c 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14736
TIME = 05-05-2021 17:46:10
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0xab 0x7c 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1c 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 446
SEQUENCE NUMBER = 14735
TIME = 05-05-2021 17:46:04
ID = 113
SEQUENCE NUMBER = 14734
TIME = 05-05-2021 17:45:41
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x8e 0x0c 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14733
TIME = 05-05-2021 17:45:38
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x8d 0x6e 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14732
TIME = 05-05-2021 17:45:32
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x56 0xcd 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14731
TIME = 05-05-2021 17:44:53
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x4e 0xc8 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14730
TIME = 05-05-2021 17:44:43
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x69 0x4c 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14729
TIME = 05-05-2021 17:44:31
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x47 0xf2 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14728
TIME = 05-05-2021 17:44:04
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x5d 0xcb 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14727
TIME = 05-05-2021 17:44:00
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x3f 0x79 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14726
TIME = 05-05-2021 17:43:46
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x5a 0x69 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1b 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14725
TIME = 05-05-2021 17:43:10
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14SCSI bus reset occurred, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7b 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x28 0x00 0x00 0x00 0x00 0x29 0x02 0x00 0x00 0x00 0x00 0x00 0x8a 0x55 0x07 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x1b 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
ID = 268
SEQUENCE NUMBER = 14724
LOCALIZED MESSAGE = Controller ID: 0 PD Reset: PD = Ports 12-15:0:14, Critical = 3, Path = 0x50000397982AE8E6
ID = 267
SEQUENCE NUMBER = 14723
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = Ports 12-15:0:14No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7b 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = , Path = 0x50000397982AE8E6
ID = 267
SEQUENCE NUMBER = 14722
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = Ports 12-15:0:14No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7b 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = , Path = 0x50000397982AE8E6
ID = 267
SEQUENCE NUMBER = 14721
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = Ports 12-15:0:14No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7c 0x80 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = , Path = 0x50000397982AE8E6
ID = 267
SEQUENCE NUMBER = 14720
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = Ports 12-15:0:14No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7c 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = , Path = 0x50000397982AE8E6
ID = 267
SEQUENCE NUMBER = 14719
LOCALIZED MESSAGE = Controller ID: 0 Command timeout on PD: PD = Ports 12-15:0:14No addtional sense information, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x35 0x7d 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = , Path = 0x50000397982AE8E6
ID = 113
SEQUENCE NUMBER = 14718
TIME = 05-05-2021 17:42:21
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x08 0xa1 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x04 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14717
TIME = 05-05-2021 17:42:18
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x02 0x07 0xf5 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00
ID = 113
SEQUENCE NUMBER = 14716
TIME = 05-05-2021 17:41:36
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 12-15:0:14Unknown Sense Code, CDB = 0x8a 0x00 0x00 0x00 0x00 0x00 0x01 0xea 0x27 0x00 0x00 0x00 0x00 0x80 0x00 0x00 , Sense = 0x72 0x0b 0x4b 0x03 0x00 0x00 0x00 0x20 0x80 0x1e 0x0a 0x8a 0x55 0x07 0x01 0x00 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x40 0x50 0x00 0x62 0xb2 0x00 0x37 0xd4 0x7f 0x00 0x00 0x1a 0x00 0x00 0x00 0x00 0x00This text will be hidden
