Zibob
June 9, 2015, 4:42pm
1
Basically I hate the caps lock key and further more I think it would be useful in games as another modifier, or failing that just an extra key to have at hand.
So the easiest way I though of it so far is to disable the Caps Lock function but keep the PC recognising it is being pressed. Is such a thing possible? Could it be done through registry editing?
You could use Autohotkey and create a script to change capslock function...
if you decide to use Autohotkey, you can easily change the function by making a script like this
CapsLock::Enter
where ENTER is any key you feel like replacing it with
CapsLock::A
will make capslock function as the letter "a"
Zibob
June 9, 2015, 5:06pm
3
Is there any way to make it function like another modifier like Ctrl, Alt and Shift for a new bank of keys in a game?
Thanks for the info. I have been looking into AutoHotKey.
OR does windows recognise an F13 key like mac? I could remap it to that and have a new usable key rather than a duplicate.
You can always change it to any other key not being used in a game, let's say if the letter P isn't being used
In Autohotkey:
CapsLock::P
Then in the game's menu, just apply P to a function and CapsLock should function as P
But remember, Autohotkey doesn't start up with Windows. IIRC I had to elevate that program for it to run as a scheduled task upon startup
Zibob
June 9, 2015, 5:18pm
5
Yes but out side of a game it would still be P. I would rather come up with a solution to have it be a new completely unused key.
Thanks for the help though these are some good ideas.
Here is another suggestion, you can make that CapsLock key work as a media key to let's say open Chrome or something.
Though I am not sure if in games it will register a media key... but off the game, it can open browsers and what not =]
