Direct X jittery
It any game I play that is using direct x it seems that there will be random stutters , which is really odd, because they all run at around 120 fps I'm using gtx 680, i7 3930k. So my computer has no problem running the games but I still get random stutters. Most extreme one is in cs:go , if I turn rapidly or open a menu it's a good 1 second tick.
Guessing I have to do some voodoo in my nvidia control panel? Also I'm running 2 displays, 1 is 120hz off dvi, other is over clocked to 75hz with a vga to dvi converter. Maybe that could be the problem I DON'T KNOW WHAT DO
Could be as simple as needing to reinstall Direct X. Shit hits the fan sometimes with stuff like Direct X, .NET, Java, etc... I'd say try reinstalling and then if that doesn't work try messing with that display adapter.
I think it's all lag from servers or some voodoo shit. Welcome to pc, were you experience will be inconsistent
Welcome to Linux, where the experience is exactly as consistent as you are willing to make it.
Linux is going to get very popular soon, but isn't going to be the linux that everyone is used too :<
