I have a gigabyte r9 270x oc gpu and have windows 8.1. I am very frustrated with these as I upgraded to windows 8 for the performance boost. And I don't have one lol. Is there any reason why this could be happening?
Have you installed the latest stable drivers for your graphics card?
Yes.
If you've donw that and done all the windows updates then I'm unsure what your problem could be. Do you have any other specific info you can give us?
Umm my full specs are:
Radeon R9 270x Gigabyte OC.
PSU: 600b evga 600 watt bronze certified.
CPU: AMD Athlon X4 750k
RAM: 4gb of corsair vengence ram.
Motherboard: MSI FM2-A75MA-E35 FM2 AMD A75
COOLING: stock
STORAGE: 500gb hard disk, 250gb hard disk, 200gb hard disk all 7200
I think its pre-installed in Windows. I can see it in the program Techpowerup GPU-Z
I think the game has to be programmed to take advantage of directx11.2. I might be wrong.
The only game that people have noticed a difference to my knowledge is Battlefield 4. http://hardforum.com/showthread.php?t=1793319
Yea, that's the reason I switched was to get better fps in bf4. But dxdiag shows that I only have direct x 11.
Both 11.1 and 11.2 are present within the DirectX library within Windows 8.1, however they are bundled and displayed as DirectX 11 by design. By default Windows 8.1 x86/64-bit carry the updated runtime environment(s) when installed.
