So I've had this dilemma for a while and I'm pretty unsure whether what would be the best option. I know nobody can decide for me, but I want to see which would be more worthwhile since X-mas is drawing nearer. And my budget is up to £400 max.
This is my build which needs a great improvement: 3rd Party Galaxy case AMD A4 5300 dual core Gigabyte FM2+ Mobo (forgotten the full name) 8gb RAM EVGA GTX 750ti SC (re-using) Generic 400W PSU 1TB Toshiba HDD (re-using) Thermalright True Spirit 90mm CPU Cooler (re-using)
This is the build I have come up with: Fractal Design Define R4 i5 6400 Quad Core Skylake CPU MSI Z170M Mortar Mobo HyperX Fury Black 8GB (4x2) 2400Ghz DDR4 RAM Seasonic M12ii 620W PSU + A game or two/FUNC KB-460 mechanical keyboard £395.94 - total
Or: PS4 console 500GB (cuh-1200) The Witcher 3: Wild Hunt Bloodborne: Game of The Year Ed. Fallout 4 DVI cable for my PC (since I'm currently using an HDMI cable and there's only one socket in my monitor) £396.78 - total
Any insight or reccommendations would be greatly appreciated.
I would go with the computer build you can do more with it and games will run faster the only reason I wold go with a console is for the exclusives but I would much rather invest that money into a computer and beside thanksgiving and xmas steam sales will be killer so you can save a lot of money from those.
Definitely the computer. You might save some money if you went Z97 since you can transfer that RAM over, and the hardware is generally a little cheaper. You'd be getting about the same performance as the skylake CPU.
So Instead on my list I've got a an i5 4460, an MSI Z97 SLI Krait Edition motherboard and some DDR3 HyperX Fury White 8GB (4x2). I really didn't want to stick with my current 8GB single stick.
That should set you up nicely for a while, also check out Streetguru's builds. If you want to go AMD you could probably get a little more bang for your buck.
Ya...Betheda's engine really likes CPUs, though I'm not sure why the FX 8 cores are faster than the FM2+ CPUs, I guess it takes advantage of multi-threading, much better than skyrim did anyways
So what am I better off going with? Sticking to my GTX 750ti + i5 4460-- or an R9 380 + X4 860k I mean it's less expensive to go for an i5 4460 with other stuff and stick with my GTX 750ti, but what would be better performance?
Hm, I'll have a look around for a bit. I do pretty much only game at 1080p and I'd only be worried if I could only run some newer games at Medium settings for 30 FPS.
