Digital Video Output, please help!
Hi guys, I'm in desperate need of some help!
I got a third monitor yesterday for my pc which is running a GTX 680. The original two monitors are plugged in via DVI but since there's only two DVI ports on that card I plugged the new monitor in via hdmi. The computer instantly froze and I hit the reset button. When the computer rebooted there was no display. I've tried each of the displays and the cables on my laptop and they work fine. I eventually used a DVI-I to VGA splitter on the pc and found I was getting video output via analog video but the other two monitors still remained blank. Looking around in device manager, devices, display settings etc it seems that the computer could not even register that the other two monitors were plugged in.
Is there any bios option or setting that may have been changed that would cause this problem? If I can avoid it I really don't want to RMA the card and have to wait a month without a computer for them to fix it.
I've already run diagnostics on the card and it tells me the card is running fine, I rolled back drivers and reseated the graphics card and still, nothing. Any insight into this problem would be greatly appreciated, thanks!
Dont panic your GPU is fine. Its the monitor. Basically what you've done most probably is shorted the monitor. Are the other two screens working?
All screens work fine on other devices with digital connections (DVI), just not my computer. That will only output with an analog connection (VGA). What do you mean by shortened the monitor sorry? I've not heard that term before
I don't think downing understood your post. It likely is the card, have you tried booting with only one monitor on DVI? If even that doesn't work then something is wrong with you card and you will have to RMA.
I have tried with a single monitor. If I use a DVI cable on the DVI-I port I can't get a signal however if I use a DVI to VGA converter and then use a VGA cable it works as per usual. My quarrel is having to send it away over Christmas and not having a computer all that time. Though I might end up buying another card and setting them up to run SLI when I get the other back.
