Basically I have acquired some studio space and I need a second computer (I really don't need it I just don't want to transport my PC back and forth everyday)
The build can either be Intel or AMD, and I don't really have any brand specific parts to ask for except for the case to be Either a Fractal or an NZXT Phantom 810
- How much are you willing to spend? I have a budget of $2950, but I would like to spend around $2600
- I live in America.
- I prefer Newegg.com and Amazon.com as my retailers, but I guess any online store will do.
- I will need two monitors, both 1080p and with IPS.
- I will need this to be a multi-use PC. I will be using Programs like Adobe Photoshop Cs6, Lightroom, After Affects, Flash, Fireworks, Dreamweaver, Design and Web and the like. If you can't tell I will be doing a lot of Graphic design and digital artwork (I sometimes get large scale projects like 18'x44' @ 600dpi), I also do video-editing)
- I'm not sure if I will be overclocking, but the option to do so should be there.
- I do not need an OS, or Keyboard or Mouse.
Also this will be used for gaming on breaks during the day.
I would like to be able to play most games on high at 60+ FPS.
This is what I was thinking:
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($309.99 @ NCIX US)
Motherboard: Asus MAXIMUS VI FORMULA ATX LGA1150 Motherboard ($289.99 @ SuperBiiz)
Memory: Mushkin Redline 32GB (4 x 8GB) DDR3-2133 Memory ($319.99 @ Newegg)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Disk ($84.29 @ Amazon)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive ($84.98 @ OutletPC)
Video Card: MSI GeForce GTX 680 2GB Video Card (2-Way SLI) ($468.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (White) ATX Mid Tower Case ($119.99 @ NCIX US)
Power Supply: NZXT HALE90 V2 850W 80 PLUS Gold Certified ATX Power Supply ($159.99 @ Newegg)
Monitor: Dell S2440L 60Hz 24.0" Monitor ($199.99 @ Amazon)
Total: $2792.16
Thanks in advance!
