Difference in these drives?
https://ca.pcpartpicker.com/parts/compare/hitachi-internal-hard-drive-0j22423%2Cseagate-internal-hard-drive-st1000lm014%2Ctoshiba-internal-hard-drive-mq01abd100h/
How much performance increase would i get is i used a typical 1tb 7200 rpm hdd VS a 1tb Hybrid 8gb caching 5400rpm ?
All disks are 2.5"
I have a 500/4GB cache hybrid drive on my laptop. I got it for my old laptop which ran very slow since I got out in 2008 and maxed out its 2GB ram capacity. At first, there was a noticeable speed difference, but then over time it seemed to have slowed down.
Even since I slapped in on my new windows 8 laptop, it seems pretty speedy. Not quite SSD speeds but somewhat close. If you're using the hybrid drive on a Windows 8 machine, I say go for it, otherwise, you're better off going with Western Digital's dual drive, which as 120GB SSD and 1TB HDD all in one drive.
http://www.amazon.com/Black2-Dual-Drive-2-5-WD1001X06XDTL/dp/B00GSJ9X4Q
Well, I am wanting to run RAID 1 in my upcoming build as the parts add up to over $2000+ CAD Those RAID 1 drives would be Mushkin Chronos 240GB SSD's
