I'm shopping for my first soundcard and was wondering what the difference between the Asus Xonar Dx and the Xonar Essence. They both have the same audio chipset, but I'm not sure if the Xonar Dx has a built-in AMP. Looking to pair either with the Beyerdynamic DT 770 250 Ohm version.
For the more expensive soundcards, they basically they put more expensive capacitors and make them look fancier.
External solutions like the FiiO E10 can often have less interference than an internal soundcard, and there's no drivers to fuss around with. Mine drives my DT 990's perfectly.
not sure what your using now for a sound card and stuff but I would go for a Xonar DG or DGX depending on what slot you want to use and price. Then get a Fiio e10 or similar to connect to it that would give you the best sound for cheap I think.
Any USB DAC like the E10 makes soundcards completely pointless - USB bypasses all other hardware in the PC.
I thought the e10 used optical? If you are connected to the sound card it helps for games mostly positional audio and such, other wise for music it does not matter as much. Just that those two sound cards have optical outs for cheap if his motherboard lacked that output.
No, the E10 is USB.
If someone wants "positional audio" as in virtual surround, Razer Surround is free software. It'll work for any equipment (including the E10) and any stereo headphones.
