Hello all. First of all here are my specs:
CPU: FX-8350
Mobo: ROG Crosshair V Formula Z
RAM: Kingston HyperX Fury Black (8GB)
CPU Cooler: Cooler Master Hyper 212 EVO
Case: Rosewill Challenger U3
Thermal Paste: Arctic Silver 5
That's what's important.
Anyways, this was my first ever build and so naturally I was nervous mostly about the thermal paste application, and since I had never installed an after market cooler before, I was a little clumsy and it pivoted a few times during installation. I used the pea method to the best of my judgment but I obviously could have put not enough, or the cooler pivoting may have messed it up?
Anyways the thing is, my CPU idles at around 46-48 Celsius. I have no idea if this is normal or not, but I feel like it should be cooler... I know my case is cramped, and horrible but there was nothing I can do about that. The case was so cramped that I had to remove the top 140mm fan because it got in the way of the top motherboard connectors including the CPU power... So the only fans I have are 120mm intake, 120mm back exhaust, and 120mm cpu cooler fan.
The temperature this summer has been around the low to high 80s Fahrenheit, but that didn't seem to affect the idle temp. at all, it always just sits between 46 and 48.
So is this too high of an idle temp? I am sad because whenever I try to overclock on this glorious motherboard everything is stable but the temp. I hit 4.8GHz in my sleep pretty much and the ONLY problem was the temp soared to 68 during the prime95 test in about 10 seconds so I had to stop it. Even at 4.6GHz it gets too hot too fast.
If it is too high, how can I fix it? I wouldn't have the money for a new case or cooler for quite some time (christmas maayybbee) but even if I could get a new cooler it wouldn't fit in this shit case. Should I try re-installing the cooler and being very careful and precise and probably slightly more generous with my thermal paste application?
Thanks in advance, ~Tas
